Can folks please add accurate HG compressed and diameter measurements to this thread.
I have scoured the net for many data points but there is a lot of variance so Id like to start again in this thread to improve the accuracy.
Here is what I have collected:
MFGR_____COMP_____dia
NISMO____0.60mm___???
Ishino___1.00mm___???
Nissan__ 1.14mm___???
Nissan___1.20mm___???
Nissan___1.25mm___???
Felpro___?.??mm___88.9mm
Felpro___1.10mm___???
Felpro___1.15mm___???
Felpro___1.20mm___???
HKS______1.00mm___91.0mm
HKS______2.00mm___91.0mm
Tomei____1.00mm___90.5mm
Tomei____1.20mm___90.5mm
I measured the 88.9mm Felpro on a spare I have. Most state 89mm.
_____________________________________________________________________________________________
Some oval shaped early L24/L26 gaskets are also mentioned but I omitted these as the volume would be difficult to calculate without knowing more details.
FYI:
part number 11044-N4221.
Stamped with the Nissan logo with the code NRZ 46F. NRZ stands for Nippon-Reinz
made in Japan.
oval ring measures 89.5mm x 87mm
features the same water passage holes that original (1971 E31 240z) head gasket had.
You would think the FelPro info would be easy to find but Noooo. Not ever on their website. Just silly...Jegs doesn't have it, Summit racing doesn't have it, Rockauto doesn't have it...
Charles
I assume that you want the fire ring thickness.  I have an old 76 HG, that I'm pretty sure is the original.  Don't know if it has any ID numbers on it though.
