Skip to content
$10 Additional LED Break light
The 60- LED blue string might be nice to light up the engine bay when you open the bonnet.
I use the LED self stick string for a 3rd light. It's totally non intrusive when it's off. Stuck to the hatch glass rubber surround.
Edited by cygnusx1
That looks cool.
Where do you get those? How did you wire it? Do you leave the wiring hanging, or does it hide away when you don't want top use the brake lamp.
Edited by TomoHawk
The thin wire is already covered in black braid, and I bundled it with the wire for the rear defrost. The I tucked the wire inside the roof trim and the rear quarter trim all the way to the brake bulb in the tail panel. You hardly see it at all. I gently spliced it into the brake bulb wires. It's just temp rigged in the photo, so you can see the wire still.
http://www.logisyscomputer.com/products.asp?PID=STRIP&DID=LED
they don't show the 12" strip but here is the link I figures out by part number: http://www.logisyscomputer.com/viewsku.asp?SKUID=LDS12RD&DID=LED
By the way, you can cut these to length if you get a longer one! They are peel and stick, but I "helped" mine with a spot of crazy glue at each end.
or here: http://www.axiontech.com/prdt_link.php?item=94434&PRICECOMPARISONSID=ubhgjkpp
Edited by cygnusx1
  • 1 month later...
Tamo3, did you get the light installed? Some pictures would be nice to see.
Is there much reflection off of the glass at night when you hit the brake? Bump to the pictures request.
