Merry Xmas all!!
I have the mallory dual point ign. in the '74. This is the car with the stroker, would I be better off putting the electric ign from my old 280 in?
I've never done the swap, is it hard?
Ideas, suggestions?
Thanks, have a great holiday!!
Brian
https://www.classiczcars.com/forums/topic/4009-280-z-ign/
HoHoHo, anything would be better than dealing with 2 sets of points......
It's a simple mod using a GM HEI ignition module (read:cheap)
http://www.sonic.net/~kyle/ztech.html
Look under GM HEI upgrade...
https://www.classiczcars.com/forums/topic/4009-280-z-ign/#findComment-21536
Uh well, no. Haven't done it, that's the reason I posted the link so I wouldn't screw up the directions....:stupid:
Mine is going to get the Crane XR whenever it is back in one large, bolted together piece....:cross-eye
https://www.classiczcars.com/forums/topic/4009-280-z-ign/#findComment-21541
B, I installed an ignition from a'79 zx and did away with the ballest resister and used the '79 coil. Works great , next time I see ya I'll show you how to do the install. You can go to geocities.com/engine/html and go to the end of all the info. there is a diagram on how to do the mod. Gary
https://www.classiczcars.com/forums/topic/4009-280-z-ign/#findComment-21622
