Hi,
I've been looking into making my own tails lights,
I know that they come up once in a while on Yahoo, but to be honest I can't be bothered, so I'm making my own.
Since I have not done molds before, I've started small.
I just poured the other half of the mold, so tomorrow I will know how it turned out.
Nigel
https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/
What did you use for resin? How did you go about making molds? How did you locate the correct colors? Details please, very interesting. I had considered a similar effort to make me a set of JDM 240z taillights.
Thanks, Charles
Thanks, Charles
The part I'm making (above) will be clear ( reverse light ),
the other parts will be 'tinted red' for the brake light.
I'll be using this dye
http://www.barnes.com.au/catalog/product_info.php?cPath=73_78&products_id=1567
this is the clear product
http://www.barnes.com.au/catalog/product_info.php?cPath=90_94&products_id=1455
I'm not 100 percent sure how it will turn out, but I will see, also I'm not sure how the resin is going to handle the uv.
this exercise is not cheap once you add the costs together, but at the end of the day, I will have molds to make lots of copies, maybe there will be a small market to sell them.
atm I have spent a good $350ish
this includes a pressure pot, vacuum chamber and vacuum pump, mold martial, clear resin, dye, and other bits and pieces. the mold martial for the above mold cost $75ish by itself, but it was the 'good' stuff and should last forever, or till I'm dead.. :-)
these 2 pictures show the Aus delivered lights ( red centered brake light), against the JDM tail lights (red outer brake light )
Nigel
Edited by Noddle
wow, thats awesome! Hope it works for you. A lot of people miss the fact that the outer red/orange light on OZ/NZ ones is actually raised. Im lucky I have sets of both, I'm sure I will cry if my JDM set was to get damaged! Can't wait to see your final result.
Nigel,
Are you currently molding the interior lens? Will you make the exterior lens in another mold and combine the 2 pieces? How would you mold a 240z taillight where the colors all meet in nice straight lines? Do you mold 2 of the 3 pieces and then put the 2 completed pieces in the last mold and let the third part bond to the first 2 while in the pressure pot?
Charles
Nigel,
Charles
The 240K tails lights come apart, so I'll mold each piece separate, and screw then together, just like the oem parts.
To be honest I have no idea how the 'Z' lights are setup, maybe you could make the separate colours, then join them with a clear over the top as you said.
Nigel
