April 27, 201114 yr Author comment_354231 courtesy nissan got back to me. yay. they dont have the baffle in stock, but gave me a number to call and a part number 11038-Y7000 as someplace in WA has it. I'll post if I get it, and thank you all ! Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-354231 Share on other sites More sharing options...
April 28, 201114 yr comment_354273 This is what this site is all about! Be sure to let us know when you receive the parts. JLP Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-354273 Share on other sites More sharing options...
May 5, 201114 yr Author comment_354845 I ordered and got the part. Looks to be original nissan, and old. I attached pics in case anyone else finds this thread and needs rough dimensions. And to repeat, this site and the community it hosts rocks. Thanks Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-354845 Share on other sites More sharing options...
May 5, 201114 yr comment_354849 Nice! Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-354849 Share on other sites More sharing options...
June 4, 201114 yr comment_357726 I finally took photos. Here they are for completeness: keywords: 240z 260z 280z L24 L26 L28 pcv baffle plate ventilation engine breather filter acid emission Edited June 4, 201114 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-357726 Share on other sites More sharing options...
June 4, 201114 yr comment_357728 Cleaned up filter area. It was filled with disintegrated/rotted filter and oil. Used Ospho acid, scrubbing and soapy rinse followed by ATF wipe. Filter soaked in solvent, blasted with brake cleaner then oiled and installed. Any hardware and threaded holes in the engine should be chased before installing. Loctite any hardware that can come loose and press down firmly on screwdriver when fastening. Done! Edited June 4, 201114 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-357728 Share on other sites More sharing options...
June 4, 201114 yr comment_357730 71 filter that has not been started for a long time. Acidic engine fumes and sludge coupled with water vapor has taken its toll. Beside it is a dirty oily filter from a '79 zx motor that will replace it. A wire with solder blobs maintains the shape of the folded filter. If refreshing I think stainless steel mesh would be a good alternative than the plain steel mesh. Edited June 4, 201114 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-357730 Share on other sites More sharing options...
June 7, 201114 yr Author comment_358044 thanks. far more complete than my quick pics. we went with bolts instead of screws to install it so in the future it can be removed without worrying about stripping the head. also got the new mesh. engine will be going in soon... Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-358044 Share on other sites More sharing options...
June 7, 201114 yr comment_358050 Blue....Nissan still has the wire mesh.....I just got some shiny new ones! Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-358050 Share on other sites More sharing options...
June 8, 201114 yr comment_358090 Thanks Diseazd! I'll probably get the new stuff. Just had to scram back to NJ for work. Car is 1000mi away. Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-358090 Share on other sites More sharing options...
January 8, 201312 yr comment_411240 Blue....Nissan still has the wire mesh.....I just got some shiny new ones!Anyone know the Part Number for this mesh? Sorry for the old thread. Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-411240 Share on other sites More sharing options...
January 8, 201312 yr Author comment_411241 No prob11038-y7000I think... It's been awhileOr was that the plate...Might be #11037-E3000 Edited January 8, 201312 yr by AnthonyG Link to comment https://www.classiczcars.com/forums/topic/39373-internal-engine-baffle-plate-missing-dimensions-engine-rebuild-in-progress/?&page=2#findComment-411241 Share on other sites More sharing options...
