Skip to content
Another 240K on eBay ( Coupe )
Thought that looked familiar... it was pretty nice back at the Qld Japanese Classics Show n Shine in 2006.... sure has deteriorated since then.
  • 4 weeks later...
Went and had a look at this yesterday, boot is good, doors are good, some of the trim ( on the boot etc) is straight as. It was painted aprox 1.5-2 years ago, there is rust appearing which you can see in the photo above the drivers side door, it's also coming up on the passenger side but not as bad, and low on both rear guards, was damp under pass side carpet starting to rust but didn't appear to be terminal. Interior has been patched/ retrimmed, not such a good job, dash is stuffed under the vinyl cover, rear cards have been trimmed, roof lining is sagging. Damage to the front isn't to bad, if you had a front section you could replace it with, the chassis rails are bent really close to the front of the car.
I was tossing up as to how I could use it personally, either use my car as a doner to fix this or the other way around and I'm still undecided, has the potential to be fixed with a front end and some decent rust repairs otherwise a lot of the parts on it would make it a good parts car. However I don't have the, just shy of 3grand he is looking for to buy a parts car.
Hope that info can help anybody if they were looking to purchase.
Cheers
