Skip to content
Dash, side and parking lights... out!
Hello everyone. I went for a night drive the other day and after going over a speed bump, my dash lights went out.
Tonight however I noticed that the side lights and the parking lights do not work either.
The fuses were all checked and replaced. The headlights, turn signal/hazards, and break lights work.
Any suggestions would be appreciated, as always.
My best guess would be your switch has a corroded or loose connection. time to get the meter out and test.
Ok I will test the switch connection or any other connections... perhaps something got bumped loose. I noticed another with similar problems, but it was for a 280z and I'm sure that the electrical system is different on them.
Different yes but the light switch assembly is close if not identical.
Edited by grantf
Search for parking lights on here. You will find plenty of threads describing solutions.
