Posted July 25, 201015 yr comment_326416 Well, got my Sandra Dee on the road today- and what a thrill! Final touch was replacing the battery, bought a Duralast Gold w/750 cold cranking amps, 935 cranking amps and 130 reserve minutes.. now it fits my car just fine- but is this too big for this application? Should I return it for a smaller one w/lower CCA or cranking amps? I don't want to damage the system- but on another note, the car likes the juice and gave me what she had! Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/ Share on other sites More sharing options...
July 25, 201015 yr comment_326417 If it fits it isn't too big I think I have the same one in my car. Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/#findComment-326417 Share on other sites More sharing options...
July 25, 201015 yr comment_326419 Duralast Gold 24DLG? I ran that in my 78 280Z for about 5 years w/no problems. Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/#findComment-326419 Share on other sites More sharing options...
July 26, 201015 yr comment_326442 Batteries are one of the few things were the biggest one is the right one. Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/#findComment-326442 Share on other sites More sharing options...
July 26, 201015 yr comment_326454 It's the physical SIZE of the battery that's important. That's where the Group 24 comes in.Too many CCA's is like saying you have too many HP's... If you use them judiciously and not punch the throttle all the time, all you'll get is better and longer use.E Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/#findComment-326454 Share on other sites More sharing options...
July 26, 201015 yr Author comment_326456 Batteries are one of the few things were the biggest one is the right one.Thank you all for understanding the simplicity of my question- but the dumb questions are the one's that aren't asked! Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/#findComment-326456 Share on other sites More sharing options...
July 26, 201015 yr comment_326458 This is the secondtime here I've read about someone thinking that too many CCAs might hurt the car. What makes you think that? Link to comment https://www.classiczcars.com/forums/topic/36606-correct-battery-size-cca/#findComment-326458 Share on other sites More sharing options...
