Hi All,
Managed to finish up the front suspension this weekend. Little bit knackered now but good to have got it all done. Just need to get a brake pedal back before I can try her out again - then of course start planning the rear swap, whoopee!
Cheers,
Rob
Originally posted by Ed
Good to see someone actually putting his jack stands in the correct place! Even a piece of wood to protect the metal:D , Nice!
Lucky guess ;)
You put in a set of RUBBER T/C bushings too,
Right??
I swapped everything up front I could find with urethane bushings, control arm, radius/tension rod, sway bar drop links, steering rack and coupler. Hopefully they should last a few more miles :D
Cheers,
Rob
  • 3 weeks later...
