Skip to content
240z Electric Fuel Pump
What is the problem with the electric pump? Did you replace the filter that is inside the pump?
Is it the stock pump for a '73 or did someone replace the mechanical pump with electric?
Or perhaps you need a fuel pressure regulator to control the pressure going to the carbs.
Edited by Darrel
my mechanic check the pump, and found out the pump is not working at all.
even change the filter..
You can probably get by for much less money than that. A generic Facet brand will cost less than half of what the ebay unit costs. Other brands are even less expensive. Does your Z have a fuel pressure regulator installed?
Dennis
Facet sells an all but identical pump to the one from NISMO - shop the Web for the best price.
Facet Part FEP60SV - you can buy replacement filters FEP 42370.
Should be around $85.00... I've used them for years...
FWIW,
Carl B.
FWIW,
Carl B.
Carl, I have a FEP60SV Facet in the back of my '73 running as a feed for the mechanical. When you run the Facet pump as the only pump, do you close / clamp off the return line? I'd like to eliminate the mechanical pump but was hesitant to block the return line
By the way, the Facet is a very quiet pump, just a faint thunk noise from the back while it's pumping. The first one I had was burned up when my voltage regulator failed but it was an unbranded Facet. It was labeled a Purolator, and was much cheaper than the Facet branded pump. Both were Made in USA surprisingly enough. I believe Facet is owned by Purolator now. My friend's tell me Facet's were the pumps to have back in the day when they were running their 510's and 18RG Celica's.
:beer:
