What kind of information are you trying to find? If you're looking for something like CarFax type information, it will be difficult.
And does it really matter with a car that is 30 years old?
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-269622
Unlike the later cars with 17 digit VIN, the earlier VINs don't contain much info on the car. An 'H' is for the L24 (240Zs) or L28 (280Zs) motor, or an 'R' for the L26 in a 260Z. The 'L' is for Left hand drive, and 'S30' is the chassis type. (S30 is the Z body up through '78 models.) A 'G' at the beginning indicates a 2+2. The rest is just a sequential serial number.
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-269624
What about my 240 ??? vin # HLS300076 / 1969 !
What information are you looking for? If you want to find out about some differences in the 1969 production cars you can do a search on this site. You can also see other information on them at www.zhome.com.
-Mike
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-269856
I'm looking for anything on my car. Its a 1977 280z stock 100% except the optium battery, fuel filter, plug wires and oil filter. It has been repainted to its origional color, and says it has 17055 miles on it. I'm not sure if those are original but my grandfather says as far as he knows they're.
What kind of information can you find out with a vin #. It does start with a HLS.
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-269863
No, really, that's about it. Nissan didn't really keep any sort of records for these cars. I've never heard of them having any form of database of VIN's and configurations for each vehicle. Aside from general figures for how many Z cars were produced per year there isn't much else.
What other kind of info are you looking for? It has a fuel injected L28 engine (N42 block), N47 cylinder head, 8.3:1 compression ratio, that kind of information?
Edited by blue 72
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-269865
How much it's worth? Is it better to keep it stock or referbish it? It runs exellent, but the engine needs cleaned. IE. Water spots. Is there any way to find out the milage? 17055 seems low even though it has been parked a airforce base. As a new owner of a 280z. What's the best thing I could do?
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-270152
Start reading, and looking at pictures.
Figure out what you want to do with it.
Spend a good amount of time reading past forum posts and learning.
Use the search feature to find out more about specific info.
Browse the galleries and see what you like.
Check out these websites.
THat OTHER forum
ZCar.com
ZHome.com
Motorsport Auto
Black Dragon Auto
Classic Datsun
And enjoy!
https://www.classiczcars.com/forums/topic/30327-car-info/#findComment-270155
