Today is my first day of vacation. Took thurs. Fri. Mon. Tues. off work and I couldn't wait to enjoy my beautiful Z over my long, perfect weather weekend and I went to fire her up this afternoon to take a nice drive and I noticed she started a little rough, then I noticed a fuel smell :( Sure enough, pop the hood and saw a massive fuel leak. It was puddling up on the intake and dripping onto the ground. At first It was tough to locate and I was thinking what the hell??? until I slightly pressed on the fuel pipe and sure enough as I did this, fuel was spraying out of the weld of the fuel pipe where it T's off and goes to the cold start valve. :cry: No big deal. I'll have to order it up and replace it but kinda bummed me out as I was looking forward to going cruising over my vacation but it could be worse :D
Thanks for listening to me vent ROFL I'm just damn glad I cought it before driving it. Could have resulted in a big fire :nervous:
https://www.classiczcars.com/forums/topic/21062-well-im-majorly-bummed/
Thanks Enigma. Yeah, she's original so it was on borrowed time I guess. funny thing is she was perfect the last time I had it out last weekend and had NO leaks. Must have been weak then when I last shut it off during the cool down process is when the hair line fracture happened. Thats my guess anyways. I'm going to replace everything All new fuel pipes A-D, new injectors with new top & bottom 0 rings and new plastic holders (which I already have purchased :D ) I already did the rubber hoses with new Nissan hose clamps. I just want to redo it ALL so I don't have this wonderful surprise happen again LOL.
It will be hard to enjoy a vacation without the Z but I'll manage :) Just have to order my parts now so I can get her fixed up:)
Hey DZR
Could you post a picture of the troubled part when you get it out. Ild like to see it.
I sympathyze with your situation, Ild be disappointed as well, but like you said better like this than watching flames roll out through the hood vents on a freeway. Lucked out.
Well I could but you probably won't be able to see it. It's a very small and I mean very very small hair line crack. Why are you having issues with yours too?
Yeah, when I saw my leak I said to myself "Well so much for taking my Z out" Then I parked her back in the garage :(
The biggest problem i have with mine is the little rubber links on the fuel rails cracking. Every summer I have to replace a few. So far this year I've had 2. Last year it was about 4 and the fuel pressure regulator. It deveolped a leak too. It sucks cuz it drips right on the exhaust manifold. I was gonna take the fuel rails off my 79 engine and switch em out since it doesn't have all the rubber links. Its solid. Sorry about your luck. Hope you can get yours fixed up soon.
The rubber fuel hoses that connect the fuel pipes should hold up longer than a year. Are you using the correct rubber fuel hoses? They MUST be ones that are made for High Pressure. If your running plain old rubber fuel hoses then yes, they will burst or crack every year as the regular rubber hoses are not strong enough to handle the high pressure so that could be a possible cause.
Yeah, I'm not one to procrastinate when it comes to my Z :D I e-mailed Courtesy Nissan and told them what I needed so I can go at it and get it done.
Hey Chris. No unfortunately. I feel like I have been educating courtesy Nissan LOL They have even asked me to e-mail my diagrams to them :D and I can't get them to e-mail :mad: They sent me there diagram so I edited theres for them by color coding the pipes I needed and labeled them then re-sent it back to them. I'm now waiting for there reply. I never thought I'd have to go through so much hell to get a couple fuel pipes LOL. They are good people there though. They don't give up and want to try and make sure they get you the right parts. Just a lot of work on my end though. When I do get the parts, I'll try and get photos up.
Don't feel too bad man. At least yours runs. On top of that, I was skimming my car to fill all the imperfections and I didn't use enough hardener and now I have to scrape the entire drivers side and the roof and start over again, so I won't be in paint this week. Hope you get your car fixed.
