I was wondering about the brand of cards between models of z cars.
I thought they were su"s but im not so sure now.
The engine is a L26 from a 74 or 75 260z. They are round tops.
Im buying the vidoe and want to make sure i get it right.
Thanks Bill
https://www.classiczcars.com/forums/topic/12304-carbs/
Yes they are all Hitachi made SU copies, even the flat tops. Bill, if you have round tops on an L26 it was converted. Without even knowing it you a right on another point. It is generally accepted that 260Z's were only made for the 1974 model year, usually reffered to as early or late (small vs big bumpers). But I have seen 260Z's with build dates as late as 11/74 and they are registered as 75's. I guess they ran behind on the development of the 75 280Z.
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86121
Originally posted by billramsey2002
Well im not sure the Engine came out of the 260. It was giving to me in a trade.
We found the numbers that lead me to think it is a L26. Ill post the # here later
Engine ID number should start with: L24, L26 or L28
If you do have the "round-top" carbs on the engine, you're headed in the right direction.
Round-top meaning that the transition from the horizontal top surface of the carb dome to the vertical side surface has a radius to it, not a sharp edge. For those reading that may not know.
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86212
Yeah mine are round tops im pretty sure. I didnt know the difference untill now thanks kmack.
It is a L26 engine. So i guess the 260zs had round toppers on em.
The motor that came with the trade has a bad block. The cylender walls are pitted somthing bad.
I was given another motor that dodint have intake or carbs. Is a L26 from a 74.
Im learning thease things just learning slow:stupid:
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86223
The 260's originally came with flat tops. Here is a picture of the roundtops on my car:
http://www.geocities.com/vintagericeracing/159.html
Round-tops have the float bowls attached to the lower side of the main carb body. The flat-tops, have the float bowls integrated into the bottom of the carb body. Plus they are much bigger than the round-tops.
And we all had to learn about these things at one point or another. Hell, I didn't know the difference in carbs until after I already had the flat-tops running on my old spare motor from a junk '73!! Talk about a waste of time!:tapemouth :stupid:
No one here will criticize you for asking questions. That's how you learn. Before you know it, you'll be the one answering someone else's questions. We've all been there.
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86228
Bill said: "So i guess the 260zs had round toppers on em"
Stephen is right Bill, no 260Z ever had round tops from the factory. Has to have been converted.
Here's a picture of the flat top set up.
Notice the square throats where the air cleaner bolts up.
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86230
Gee, thanks a lot Chris.....seeing that picture sent shivers down my back as I remembered rebuilding those damned boat-anchors so many years ago! :tapemouth :tapemouth :sick: :tapemouth
To think, I actually had them working pretty good. Live and learn
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86232
Hey Kmack, gives me the heebie jeebies too, I have a set at home on a shelf. I curse them every time I walk by.LOL LOL LOL
Then I look at the ztherapy roundies on my 73 with the milled shafts and roller bearings and just smile!!!:classic:
Chris
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86235
From the pics mine look like round tops. I will post a pic o them when i get a bat for the digi.
Kmack i have been criticized for asking dumb questions.LOL
remmember i was wondering the common fusty spots in a z:stupid: total no brainer that day!
https://www.classiczcars.com/forums/topic/12304-carbs/#findComment-86250
