Send a PM to Kmack, he found stainless allen head screws that fit.. he could tell you what exact size you'd need to replace them.... You could probably pick them up at most hardware stores, ot Home Depot/Lowe's.....
If you don't have an impact driver, use the "poor man's version" like I did: I put a #2 philips head in the stuck screw and tapped with a hammer. Don't go crazy as you might distort the housing. I think some of the problem comes from dissimilar metals having been together under pressure and temperature for a long time. That makes them want to stick to each other. The tapping helps break them loose.
It's worked for me so far on 3 out of 4 carbs I've dissassembled. (The 4th didn't have any problems removing them.)
Daniel's method has been mine too for the quite some time. through roadsters 510's z's, well, let's just say a "S" load of SU's. Now, just about every phillip's head screw I remove gets a couple taps for good luck. Of course, this is from a guy that a ball pean and a torch are his favorite tools. ROFL
i had the same issue , i switched from the phillips to a regular screw drive and had someone hold the carbs as I leaned into it to put pressure on it and they came out ok , but even the z therapy video says use a regular screwdriver , good luck:geek:
  • 1 month later...
Yup, I got them off with a regular screwdriver. Cleaned them up real good, put them back on and now the car doesn't start. It tries to start and backfires. I haven't bothered with it since before Christmas but will get back to it in the next couple of weeks.:ermm:
well, the float bowls will have to get full of fuel, and also make sure the pistons go up and down smoothly by hand....that's really all there is to it....might take a few cranks to get the fuel level up so it'll start, might try starter fluid too....
