Best coolant route for turbo? - Open Discussions - Classic Z Car Club Skip to content
Any recommendations for coolant paths for a turbo? (Turbo on passenger side vs under intake)
I'm currently feeding the turbo from the thermostat housing and the return is going to the water pump inlet.
I'm thinking about changing away from the thermostat housing which I have to run a long 3/8 line which I feel isn't giving it enough.
I was thinking about running a closer line from a currently plugged heater core exit on the back of the block (F54 block)
I’m certainly not a turbo guy. Doesn’t the oil pan have a return feed for oil feeding the turbo? The reason I ask is ArizonaZ car forgive me if I have the company name wrong. If you search on that they produce an aluminum oil pan for that return feed.
thanks for the comment, typically turbos need oil and coolant. I already have an oil feed from a sandwhich plate on the oil filter, and an oil return going to the oil pan.
Im asking more about where the best place to take a feed for the coolant to the turbo.
It looks like most pull coolant from the thermostat housing. I'm not sure where it would return to the engine though. Protunerz.com seems to have quite a lot of specialty built products for it such as coolant lines, modified billet thermostat housing, etc.
https://protunerz.com/collections/cooling/products/new-datsun-l-series-billet-thermostat-housing-set-v3-water-neck-v2
Keep us updated on your build, I'd love to see how it turns out!
Mike
