71 240z that's been sitting.... - Page 2 - Open Discussions - Classic Z Car Club Skip to content
And as @Zed Head says you'll probably end up doing more. There were 3 things I listed above that I think didn't "have to be done" to wake the car up were the headers/exhaust, ZX dizzy and the electric fuel pump. Other things I did were the 60Amp alternator upgrade from MSA with the internal regulator eliminating the mechanical regulator, the Dave Irwin headlight harness to eliminate the high power draw through the combo switch & fusebox, all LED lights except the dash, replaced the seats from a 77 Z so I had the full seat articulation (leather for new seat covers, shift boot & ebrake boot), Wesco Roadster retract seatbelts, bluetooth RetroSound radio & new speakers, Rota RB wheels with new tires. Yes, there's a few more things on my list, but I think I'll have to hire them out so saving up for them, suspension & A/C.
@w3wilkes ... Thanks for your story... what you outlined when you went thru your 71 Z, is pretty much what I was thinking for my 71.. I'm debating the electric fuel pump conversion.. leaning towards doing the conversion when the tank gets dropped.. be nice to have the car start up after a few cranks, instead of having to wait for the mechanical pump to prime the system... Also looking at swapping out the stock radiator, for a newer aluminum one, but it the stock one is still good.. I'll probably go with it for the time being... I've already changed out the stock dizzy for a Malory Unilite dizzy and a MSD 6A unit, and replaced the stock gen for a newer GM alt conversion... I'll probably sit on the stock exhaust system for now, if it works and not leaking.. When Dave Irwin was still on the board, i had him re-build the steering wheel stocks and did the head light relay conversion already, and changed out the fuse box due to the main feed melting issues. I got MSA seat rebuild foam and covers that need to get installed on the factory seat frames, already did the seat webbing.. Besides everything that's already been mentioned, I am going to have to have the springs and shocks replaced.. yeah there is a lot of stuff that'll need to be address, won't know what until I start digging into the car, just hoping it won't be a longgggg list
