Skip to content
Hatch drip gutter extension
@Chris Holt
When you have time read about this cause of water rusting the slam panel at the hatch. You might think up a clip on and removable extension for our cars. I would be interested if you came up with something other than welding like @grannyknot did on one.
I think about it when I wash my car and dry it off then not again. It's not too big of a deal anymore since no one drives in the rain or parks their car outside. You might sale a few though?
I see now, any add on couldn't continue the water past the end of the hatch.
Keeping mine waxed and dried asap is the better solution.
Even though Grannyknot made his gutter extensions out of sheet metal and welded them into place before applying his the final paint coat, you could just as easily fab up something similar and just glue them in place. Make them out of 'L'-section plastic (hobby store) to address rust concerns and paint them body colour before gluing to the hatch body sill.
Edited by Namerow
made more better
How much for both sides? 🤭
Kidding around. It does seem simple but I would be concerned about the length to clear the slam panel when the hatch is closed. It would be very close without breaking the extensions when you shut the hatch. ????
Worked for Grannyknot using zero-forgiveness sheet metal. I don't see the problem.
I don't have access to any cars at the moment to work a design out- the challenge would be to get a tight seal.
It probably why my mate who has one said keep them out of the rain and if it is outside park it up hill. Think he was being a bit tongue in cheek.
