Skip to content
1972 240z tachometer not reading nor working with MSD blast 2 coil. Any solutions?
44 minutes ago, Yarb said:
@cgsheen1 made a suggestion, Are you not willing to try it? Takes 2 minutes.
Ill try it! See what happens. Right now we have the pertronix 1.5 coil installed with 1.5 ballast
2 hours ago, 72 Datsun 240z said:
The thing is my mechanic solved the rough idle and misfire after take off from long traffic by installing an msd blaster 2 coil replacing the pertronix 1.5 coil and 1.5 ballast resistor. The problem is the stock tach does not work with the msd coil which i believe is 0.7 ohms. Going back to the pertronix, the tach worls but the car runs bad.
Maybe this is the point where you decide which you want most - working tach or good running engine...
Back when I learned to drive - and for years thereafter - cars didn't come with tachometers. They ran and we drove them all over the place anyway.
(but, from the factory that car ran VERY WELL with a stock coil, a stock ballast resistor, a stock distributor, AND a stock tachometer. Just sayin')
You are right! Mechanic should get this engine running with pertronix ignitor module 1761, 1.5 coil and 1.5 ohm ballast.
Well just to let you know mechanic managed to make the 240z tachometer work with the MSD Blaster 2 coil which i believe is 0.7 ohms and pertronix 1711 ingitor module. I hope it doesnt burn the 1711 ignitor.
On 9/2/2025 at 10:31 AM, w3wilkes said:
You didn't mention which TachMatch Device you installed? I did a ZX matchbox distributor with removed resistor on my 12/70 car. My tach almost works but doesn't seem to go any higher than about 3500 RPM.
This is how the msd blaster 2 got wired to the tach, distributor and ballast. Hope im not missing anything. Tach is working but plug 4 is still getting fouled at idle.
