1980 Ground Up, DATSUN 280ZX.
Body completely disassembled, stripped of all paint, undercoated with POR15 & painted. No damage or rust.
ENGINE; L28 with Euro-Top pistons, P79 head, ported & polished and CC`d. 60mm throttle body, custom intake manifold both Jet Coated, custom fuel rail with 14mm o-ring injectors. Wolf 3D engine management system with 6 Denso Coils,  sequentially triggered. Center Force light weight flywheel & clutch.
SUSPENSION; Polyurethene Bushing, KYB shocks, Suspension Technique sway bars, R200 differential 3.54.1, Panasport Wheels F15x6, R15x7. 8,302 miles since rebuild. Not driven in the rain.  All receipts available.
Much more
$18,000.00
https://www.classiczcars.com/forums/topic/69397-1980-datsun-280-zx/
What are Euro-Top pistons? What did the chambers measure out at? Just curious about compression ratio.
You should add a driving video. Good luck.
  • 3 weeks later...
Sorry for the delay in getting back to you. JE Piston Manufacturing started business in the early 1900's. They are known for their exceptional forging and machining quality. Thank you for your response.
Mike.......datsun79z@aol.com
