April 28, 20232 yr Author comment_653108 3 hours ago, bartsscooterservice said: Looks like the typical wrong jacking up of the car. The floors don't look bad at all from the pictures, why did you replace them , or was their hidden rott we can't see in the pictures? Most likely the case, damage that was done by the previous ownership. Passenger floor pan had rot where it overlapped the frame rail, right under the seat brackets. The drivers side probably could have been saved. It had some rot where it met the firewall and a few big dents I was worried would never fully come clean. Gambled replacing the entire panel would be quicker than all the smaller jobs. Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-653108 Share on other sites More sharing options...
April 28, 20232 yr Author comment_653109 1 hour ago, dutchzcarguy said: Don't forget to look at the inside of the outer beams (between the wheels..) that should be the place to lift your car.. not the inner beams! (use a endoscope, sometimes the lower part of the inner plate in the beam is completely gone, and it makes the changing a wheel with a normal jack a desaster.) Take a look in the servicemanuals.. It's gonna be a nice car!! Absolutely, I’ve got special pucks I made with a notch down the middle to slide over these jack points for the 2 post Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-653109 Share on other sites More sharing options...
April 28, 20232 yr Author comment_653110 Just about done with the AC hardlines. Once I get the dash built up I’ll finish plumbing these up to the Vintage Air unit. Edited April 28, 20232 yr by CW240Z72 Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-653110 Share on other sites More sharing options...
April 28, 20232 yr comment_653139 Nice clean looking install! Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-653139 Share on other sites More sharing options...
June 26, 20231 yr Author comment_654503 Massive photo dump impound - bunch of progress made over the past few months Full T3 suspension going under the Z. Color choices from T3 aren’t the best, that’s in the works to change BC extreme low coilovers Ztrix dash also arrived. Top notch piece from John. Lots more to come on this Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654503 Share on other sites More sharing options...
June 26, 20231 yr Author comment_654504 Lots of hardline fabrication Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654504 Share on other sites More sharing options...
June 26, 20231 yr Author Popular Post comment_654505 Tanks Inc in-tank fuel pump installation Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654505 Share on other sites More sharing options...
June 26, 20231 yr comment_654518 I just found this thread, outstanding fabrication work! Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654518 Share on other sites More sharing options...
June 27, 20231 yr comment_654530 Why did you decide to take the clutch slave line through the passenger compartment? Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654530 Share on other sites More sharing options...
June 27, 20231 yr comment_654531 The fuel tank work looks really clean! Actually all the work looks really clean but I found the fuel tank work to be a very creative solution Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654531 Share on other sites More sharing options...
June 27, 20231 yr Author comment_654537 1 hour ago, Patcon said: Why did you decide to take the clutch slave line through the passenger compartment? Purely aesthetics. I didn’t want to cross over the fuel lines with it as they’re routed right above the clutch line. I’m getting really good at making simple things harder. Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654537 Share on other sites More sharing options...
June 27, 20231 yr Author Popular Post comment_654538 Getting color on the body. Previously on the fuel tank we sprayed the top coat with Raptor Liner, reduced enough so you could use a traditional HVLP gun. This gave a very fine texture, similar to what’s on the dash. Really liked the finish so we replicated the same procedure with the underside of the car in the factory color. Link to comment https://www.classiczcars.com/forums/topic/68167-building-up-hls30-59920/?&page=4#findComment-654538 Share on other sites More sharing options...
