Modern Relay replacements for 280Z Fuel Pump Control Relay and Electronic Fuel Injection Relay?
12 minutes ago, Zed Head said:
I was just using the schematics of those relays to show the possibility.  The web page has the option of setting your specifications.
Just have to put the work in.
https://www.boschautoparts.com/g/relays
Indeed. Since the Nissan EFI has the ignition pulse to the ECU, there is no reason to use anything complex here, just a question of single or double throw.
2 separate relays is my Plan B, but I would like to use as few relays as possible because I will also add new relays for the headlights and an electric fan .... and I fear I might be running out of space.
But if there is no other way I will go down that route.
Thank you for the link, that helps a lot.
The problem is that for the one relay you need a dual coil and a suitable relay base. You won't find that in a Bosch style relay. If you are lucky, you might find such a relay made for another car, but you would still need to add the base if you can find it.
You will probably end up using two relays or doing the smart thing and staying with the factory style relays.
Any double function (assuming you can find one) relay is going to take up as much physical space as two standard relays. At that point it makes more sense to stick with the factory setup. You can buy 'gangable" relay sockets for Bosch style Micro and Mini relays, so you can keep it pretty compact space wise.
I will probably be using 2 relays. The advantage of the Bosch style relays is that that they are still available and easy to find in case they need to be replaced.
I will also keep some of the original relays, but I want to keep the amount of them to a minimum.
Hi All, I have one new replacement made by Lucas (German brand) for the relay AI3 000 002. I bought for my Datsun280Z/78 but afterwards realized that for the 78 model is different. If anyone needs this relay drop me a line.
Cheers,
There is a saying in the US - "why do the British drink warm beer? - Because they have Lucas refrigerators" 🤪
gratuitous prejudice
there is an answer to that, relevant in the case  that someone actually needs the relay https://www.hemmings.com/stories/article/the-lucas-jokebook
notice that the relay was made in Germany
Edited by DHA280Z
As an aside - I'm actually English - moved to the US when I was 19 - I used to own & work on British cars after I moved here. I was quite insulted by the joke at the time. It did seem to be true unfortunately.
  • 2 years later...
Replying to this thread a few years later - The Bosch relays have become extrmely hard to find now and are being sold for $200+ if you can even find them. are there any solutions for this?
I need to replace this relay to get my engine running but im planning on moving to a megasquirt system in the future.
https://www.jbugs.com/product/071906059.html
