May 11, 20187 yr Author comment_549098 Hi 7tooZ. Thanks I’ll check it out Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549098 Share on other sites More sharing options...
May 11, 20186 yr Author comment_549171 Hello guys I finally tracked the green wire but not sure ? where this connect to. Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549171 Share on other sites More sharing options...
May 11, 20186 yr comment_549173 Are they solid red and green Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549173 Share on other sites More sharing options...
May 12, 20186 yr Author comment_549174 Green and white and I think solid red Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549174 Share on other sites More sharing options...
May 12, 20186 yr Author comment_549176 Sorry 7tooZ red and blue not solid Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549176 Share on other sites More sharing options...
May 12, 20186 yr comment_549177 What color is the stripeSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549177 Share on other sites More sharing options...
May 12, 20186 yr comment_549178 Green/white and red/blue is usually instrumentation lighting. Dash lights, HVAC illumination, ash try light... That sort of thing. I can't tell from that close-up where that connector is, but I suspect it's for a bulb somewhere. Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549178 Share on other sites More sharing options...
May 12, 20186 yr Author comment_549179 Currently no dash lights no park lights. That connector located under the dashboard behind the fuse circuit. Check the continuity from that connector to the white and green cut wire in question from my original post and there’s a continuation. Also there’s a continuity with the blue/green and the missing wire on the second picture when combo switch is in park or on Link to comment https://www.classiczcars.com/forums/topic/59997-combo-switch/?&page=3#findComment-549179 Share on other sites More sharing options...
