Skip to content
High performance valve springs
Just seeing if anyone has some performance valve springs for a high lift cam laying around . Maybe a matching cam too
I've got a new Rebello set that you use with your stock inner and the Rebello outer spring and a stock retainer that you can use with up to a .500 lift cam and up to .220 lash pad. Also have a new Isky regrind Stage II .485 lift. I use all Stage III.
