Skip to content
1977 OE hitachi radio MOUNTS
All the other diodes have the diode symbol printed on the circuit board and the red band is the cathode side on them.
Ok had to go back and re read up on this some.
the anode is technically called the positive side hence the red tubing. I was thinking in power supply circuits where the Positive side of the power supply is the cathode since that is the flow of current.
Anyway the band should go to the brown side from what I can see.
Edited by Dave WM
thdiode14.gif?x98918is how I was thinking it note the cathode side is the positive output.
So I "think" the red tubing was a way to denote anode, in case the brown marking was not enough to denote the cathode.
Edited by Dave WM
It's not a big problem if the diode is in backwards. The current just won't flow thru the circuit.  I'm more concerned why these things burned up
I'm thinking they put in ones that were too small.  I'm thinking the gears got harder to turn over the years and the motor drew more current than
they designed for that circuit.
I've got a 1n4001 and will pop it in this spot.  Play smoke on the desk instead of the water LOL
no fire in the sky? I remember when that album came out, had a very high PAF (parent annoy factor).
So i thought i'de fixed the radio part of this player by reseating the 4 big transistors on the back but I was wrong. I must have jostled this resistor and it came back to life for a while but i lost the radio sound  when i was putting the
case back on. FRUSTRATING. So, an oldschool technique is to wiggle, prod, shake things until something happens. This is the result.
