May 12, 201312 yr comment_423211 Bad float adjustment? Why did you adjust them? Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423211 Share on other sites More sharing options...
May 12, 201312 yr comment_423215 I have quite the collection of jets anymore, so if you want to try something different, I can lend you some before you buy Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423215 Share on other sites More sharing options...
May 12, 201312 yr Author comment_423227 I re-tightened the manifold/exhaust bolts last night to no effect. Last night the car was backfiring though 1, 4 and 6. This morning I removed the manifold and exhaust and replaced the gasket with a felpro unit applied dry. I had a new set of exhaust and intake studs laying around so I replaced them while I was there. The car now seems to idle more roughly than it did before the gasket replacement and it pops quite badly though #4 and #6. The backfires are now more intense than they were. I plan to let the car cool and re torque the gasket. Any advice for getting the intake to seal? Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423227 Share on other sites More sharing options...
May 12, 201312 yr comment_423229 How do you know if and where the intake is leaking? Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423229 Share on other sites More sharing options...
May 12, 201312 yr Author comment_423231 I've tried flowing propane, carb cleaner and water around the flanges with the engine running to no effect. I'm not sure how to find the leaks. Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423231 Share on other sites More sharing options...
May 12, 201312 yr comment_423239 Sounds like you need to recheck your floats Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423239 Share on other sites More sharing options...
May 12, 201312 yr Author comment_423240 Sounds like you need to recheck your floatsI checked the float levels by removing a jet block from each carb. The float levels look normal and even between carbs. I would also expect that if the floats were to blame that pairs of cylinders would misbehave as one float adjustment services two cylinders.I re-torqued all the bolts and the car still backfired. I then started turning the idle mixture screws to richen up the cylinders that were popping and lean out the ones that weren't. With this adjustment the popping/backfiring has stopped. I ended up with the following mixture adjustments per cylinder.1 = 1.75 turns out2 = 1.25 turns out3 = 1.25 turns out4 = 2.0 turns out5 = 2.0 turns out6 = 2.5 turns outI assume that the extra fuel requirements of some cylinders is a function of a specific vacuum leak in that cylinder and potentially carb to cab differences in the idle fuel system. This is a bandaide solution for some underlieing problem(s). The search continues. Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423240 Share on other sites More sharing options...
May 12, 201312 yr comment_423247 AFR? Are you good after your pilot screw adjustment? Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423247 Share on other sites More sharing options...
May 12, 201312 yr comment_423248 Have you checked valve lash just to be sure it's a carb problem?By cleaning and resealing the carbs and intake, you could've revealed some issues that were masked before. Edited May 12, 201312 yr by LeonV Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423248 Share on other sites More sharing options...
May 12, 201312 yr Author comment_423249 I checked the valve lash a couple of months ago. All was good no adjustment needed. AFR is in the 11's at idle. I can't drive the car right now as I took the rear stub axel off this morning to replace a grumbly bearing. Should have it back on the road for a test drive on Wednesday. Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423249 Share on other sites More sharing options...
May 13, 201312 yr comment_423324 So, do you think that the porting caused a lean condition by allowing the motor to flow more air? Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423324 Share on other sites More sharing options...
May 18, 201312 yr comment_423672 I know you said timing looks normal...have you tried advancing the timing a few degrees to see if it smooths out? Link to comment https://www.classiczcars.com/forums/topic/46522-why-are-my-mikunis-backfiring/?&page=2#findComment-423672 Share on other sites More sharing options...
