October 15, 201311 yr Author comment_433800 Some good news to redeem this thread. Lemon juice works great on cleaning brass jets, correctors and e-tubes from side draft carbs. I just tried it in a dish and place the parts in it and swished around. The black deposits and corrosion disappeared and they brightened right up. I then heated the lemon juice in a microwave and it worked a little faster.A neat benefit is that it unsticks tight holders, jets and air correctors. They loosen up and can be easily disconnected by hand when some previously needed a tool to separate. Edited October 16, 201311 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-433800 Share on other sites More sharing options...
October 16, 201311 yr Author comment_433836 Comparison with original and dipped/soaked for 2 hours and just dried. The orange/copper colour lessens through hand rubbing with a cloth and a brilliant yellow shine appears . Sad to see one of the 6 F11 e-tubes is an F2 ... I bet the PO had fun tuning. I also noticed the lemon juice did not remove crust in the grooves of the accelerator pump piston. I think ultrasonic cleaning in a solvent and a mild acid like the lemon juice would be best form of cleaning. Edited July 16, 201411 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-433836 Share on other sites More sharing options...
October 16, 201311 yr comment_433838 That's great result! Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-433838 Share on other sites More sharing options...
October 16, 201311 yr comment_433839 Very nice! Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-433839 Share on other sites More sharing options...
October 17, 201311 yr comment_433893 Household vinegar works great on copper, brass and bronze, not so well with aluminum, it is the difference from citric acid in the lemon juice & acetic acid in the vinegar. Gives any copper based object a new look if you don't want an aged patina. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-433893 Share on other sites More sharing options...
October 17, 201311 yr Author comment_433896 Thanks Bonzi! I just tried both for 30min (soak then rub with paper towel). The vinegar cleans faster and better (look at the carbon on the top holder). The lemon seems to be less yellow in tint but shinier. Have a look: Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-433896 Share on other sites More sharing options...
July 16, 201411 yr Author comment_451670 OK I gave it another go: Enamel pot on the Barbie with lemon juice and some vinegar. Rolling boil for ~ 20min is the trick. It degreased the carbs and the carbon flakes off. Here are some pictures: Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=3#findComment-451670 Share on other sites More sharing options...
