Posted May 25, 201114 yr comment_356782 Guys, my '71 has no vent tube on the rear differential. I'm sending my fresh redline all over after a freeway drive. Probably a dumb question, but is the 71 supposed to have the standard type vent tube? If so, can you still buy a vent tube? Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/ Share on other sites More sharing options...
May 25, 201114 yr comment_356785 Looks like you can get one here:The site does not seem to have Z's so I entered a 280zx automatic (which I believe has an R180 differential)http://www.nissanpartszone.com/online/Page_Cart/ListShoppingCart.aspx?previousURL=(%2fPage_Product%2fPartDetail.aspx%3fModelName%3d280ZX|ModelYear%3d1979|ModelSeries%3dS130|FileType%3d268|SelectConditions%3d(1%3d2S%3b2%3dL28E%3b3%3dJ%3b4%3dAT%3b5%3dF3%3b6%3dC%3b7%3dFED%3b)|ShowConditions%3d(1%3d2S%3b2%3dL28E%3b3%3dJ%3b4%3dAT%3b6%3dC%3b7%3dFED%3b)|seeDesc%3dFalse|goBack%3dTrue|SectionNo%3dF|ComponentsNo%3d380|ComponentsIndex%3d15) Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356785 Share on other sites More sharing options...
May 25, 201114 yr Author comment_356795 thanks Blue!! Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356795 Share on other sites More sharing options...
May 25, 201114 yr Author comment_356843 Holy Crap.....the part is $1.34 but they want $12.00 for shipping..............uuummmm...NO. Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356843 Share on other sites More sharing options...
May 25, 201114 yr comment_356845 They are fairly easy to twist out of the top of the diff. You might go to a local wrecking yard with a pair of pliers. Don't squeeze too hard if it's a plastic one. I think that the later Zxs came with metal. Maximas and maybe Subarus might use the same went. Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356845 Share on other sites More sharing options...
May 25, 201114 yr comment_356854 Just tap the hole for a barbed fitting and run a hose with a loop in it. Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356854 Share on other sites More sharing options...
May 25, 201114 yr comment_356856 "Just tap the hole for a barbed fitting and run a hose with a loop in it."Clever! Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356856 Share on other sites More sharing options...
May 26, 201114 yr Author comment_356869 I think i will just tap it and put a fitting in there. John, do you know off hand what size tap I should use? Link to comment https://www.classiczcars.com/forums/topic/39672-71-differential-vent/#findComment-356869 Share on other sites More sharing options...
