Posted May 14, 201114 yr comment_355790 Hey guys I got a set of wheels with tires last fall for a super steel. A buddy of mine practically gave them to me. The problem is they don't fit my 280. I tried to put them on but they were just touching the coils on the front. What Im wanting to know is what spacer size I need and where they can be had the cheapest. Im pretty much a noob about all this so forgive my stupidity.The stats:5 spoke ADR 58 18x7.5Tires: NANKANG Ultra Sport NS II215 35R18 84HThis is pretty much the wheel I got, with a slight cosmetic difference: http://www.maxspeedperformance.com/xcart/product.php?productid=12429&cat=22They came off a 2000 Infinity g20Thanks guys! Edited May 14, 201114 yr by nhines3 Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/ Share on other sites More sharing options...
May 15, 201114 yr comment_355792 WAG - 25mm.To be certain, you're going to need to find the offset of those wheels. For a 7.5" wide wheel, you probably want a total offset of around +10 or so. So if the rim offset is around 35 (as I'm guessing), a 25mm spacer will give you an effective +10.The offset may be stamped on the back side somewhere, sometimes as 'offset', others as 'ET'. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355792 Share on other sites More sharing options...
May 15, 201114 yr Author comment_355812 I believe it's a 42mm offset. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355812 Share on other sites More sharing options...
May 15, 201114 yr comment_355832 Most auto parts stores carry them. MAKE SURE YOU DO NOT CHEAT YOURSELF OUT OF STUD WHEN ADDING SPACERS! If you have to add too much spacer to get at least 1/2 inch thread get longer studs or you could loose a wheel. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355832 Share on other sites More sharing options...
May 15, 201114 yr comment_355843 42? Ouch. You'll need 30-35mm spacers then. Spacers that thick should not require longer studs, as they will bolt to the existing studs and have built-in studs for the wheels to bolt to. They won't be cheap. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355843 Share on other sites More sharing options...
May 15, 201114 yr comment_355844 You got pics of the new wheels on the car? Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355844 Share on other sites More sharing options...
May 15, 201114 yr Author comment_355857 You got pics of the new wheels on the car?I'll post some pics of the wheels and the insides of the wheels. Im going to sandblast and repaint them a different color before I put them on the car though. Pics to come later today. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355857 Share on other sites More sharing options...
May 15, 201114 yr Author comment_355880 Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355880 Share on other sites More sharing options...
May 16, 201114 yr comment_355934 Ouch, et40, or +40 offset... Arne is right you'll need either a 30 or 35mm spacer. It will bolt on the existing studs and have another set of stud the wheels will bolt to.I"m not sure where to find a spacer larger than 30mm. You might need to do some searchinghttp://www.evasivemotorsports.com/merchant2/merchant.mvc?Screen=CTGY&Category_Code=Kics_Wheel_SpacerYou may also be better off getting a wheel that fits better. The cost of the spacers alone are basically another set of wheels. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355934 Share on other sites More sharing options...
May 16, 201114 yr Author comment_355939 I found a pair on ebay for $85, so that would be $170 for all four. Considering those wheels are $150ish a piece without the tire, Im going to make them work. I got the whole set with tires for $140, so Ill be into it for $315 by the time im done. Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355939 Share on other sites More sharing options...
May 16, 201114 yr comment_355988 Motorsport Technology has spacer/adapters where the spacer bolts to the hub and the wheel to the spacer. Running longer studs and 30-35mm of spacer would be asking for trouble. If you give them the hub OD and wheel ID they will custom make them both hub and wheel centric. I have a set on the front of my Datsun 1200 racecar.http://www.motorsport-tech.com/ Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-355988 Share on other sites More sharing options...
May 17, 201114 yr Author comment_356008 I think this is the route Im going to go. http://cgi.ebay.com/ebaymotors/HUBCENTRIC-WHEEL-SPACERS-ADAPTERS-30MM-280Z-1975-1978-_W0QQcmdZViewItemQQfitsZYearQ3a1978Q7cModelQ3a280Q5AQQhashZitem255d6e2565QQitemZ160481289573QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Link to comment https://www.classiczcars.com/forums/topic/39576-wheel-spacer-help/#findComment-356008 Share on other sites More sharing options...
