Skip to content
fender pics
If anyone has or gets a chance to take a picture of the bottom rear front fender where it mounts to the body...it would be a great help. fenders were rusted so bad i cant tell how the bottom is supposed to look. im not using a repair panel so a picture will help me get it close to right. i probably should have put this in help section. sorry
Brian
Edited by pjoe
probably should be help section
I have pictures, lots of pictures of my car and I might have the one you are looking for. My car is less than 25' from my bed so I can get pictures if not. To help can you take a picture of the area in question so I can get what would help you out the most?
here is the front left fender. curious as to what it should look like. pretty sure i cut to much off bottom of new(now rusted) metal.
It is to dark now and cold I'll take some pictures tomorrow. It loooks like your missing a bracket that the fender bolts to you'll see tomorrow
How did you get the screws out of the bottom? It looks like a phillips head using a smaller bit than usual.
I had to go out to the garage anyway - and it's warmer here.
Here is picture...
FWIW,
Carl B.
thats exactly what i needed. thanks carl. hopefully get these things bolted up this weekend. definately need to redo what i already did. should have seen a picture before i cut the extra 3 inches off. oh well f it.
Ya Carl looking good like ushual. Can't wait for mine to look that way . . .
Hear are some pictures I took them from the right easier to get to in my garage I some of the back side in case you might want them. Besides Carl was first with the underside picture
Edited by ajmcforester
cool thanks for the pics. theyre all helpful. wasnt sure if i needed the lip on the bottom all the way across but now i see. your right i need to weld that bracket in for the back bolt. carls car looks too clean...i would feel bad driving his as hard as i will drive mine if i ever get back on road.
Without that mount point you would be flapping in the wind. I wish I had a fender off picture that would really help
