Seems I lost the screw that holds on the fan switch knob. Anyone know the size?
We don't have metric fasteners that small at work or in local hardware stores, so I can't find out the easy way by "trial fit".
https://www.classiczcars.com/forums/topic/36271-thread-size-for-fan-switch/
Timely question. I too need the same information. My fan switch just rotates and I need to secure it.
It would be metric - I will see what I can do tonite - am I correct thinking that it would be the size of a metric socket head that it would fit into?
my GUESS is its a 10mm
Dave
When I was replacing one years ago, I found that Allen Hex Head screws were readily available.
Granted you lose the ease of using a straight edge screwdriver, but you gain the ease of finding a source.
Don't recall the size or thread pitch, but I used a tap from my tap/die set to determine which one.
FWIW
E
Oh for heavens sake... (OFHS ) 10mm.... :rolleyes:
The fan switch knob screw is a 3mm x 0.5 mm pitch. Its 7.6 mm long with 4.5mm of thread.
To find something similar, think hobby shop, like a good one with lots of parts for RC cars and planes.
Maybe even an electronics supplier that sells volume control like- devices and their respective knobs might have something.
Jim
Edited by zKars
