Posted July 17, 200916 yr comment_289836 I am trying to finish this restoration on a 1971 240Z. {3/71}I need these hoses. part # 17238 E4601 and 17243 E4100. Nissan says they are not available. The local parts guy wants to sell me coolant hoses. Does anyone know where I can get either the correct hoses or quality aftermarket hoses ? The part #'s are from the Club CD-Rom. Thank you, Darrell 240Z Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/ Share on other sites More sharing options...
July 18, 200916 yr comment_289841 Take a look at this thread that Arne did about the fuel hoses a couple of years ago http://www.classiczcars.com/forums/showthread.php?t=25857. It looks like 17238-E4602 replaced 17238-E4601. I think 17243-E4601 is NLA, but Arne substituted 17236-E4601 for it.-Mike Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289841 Share on other sites More sharing options...
July 18, 200916 yr comment_289843 You definitely want to use fuel rated hose for all of these hoses. I was able to order 17239-E4601 and 17235-E4601 from www.nissanparts.com. 17238-E4602 was NLA so I used (19mm or 3/4") fuel hose for this one, and 1/2" fuel hose for 17236-E4601. If you can't get 17239-E4601 from there I saw one on eBay.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370230424835 Edited July 19, 200916 yr by =Enigma= Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289843 Share on other sites More sharing options...
July 18, 200916 yr comment_289848 Banzai Motorworkshttp://www.zzxdatsun.com/catRequests.phpScroll to the bottom of the page and you'll see the image of the vapor system. Good Luck. Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289848 Share on other sites More sharing options...
July 18, 200916 yr comment_289850 You can fine 5/8'' fuel hose at Napa , this is what I used. Do not use coolant rated hose for gas ever. Gary Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289850 Share on other sites More sharing options...
July 18, 200916 yr comment_289856 Banzai Motorworkshttp://www.zzxdatsun.com/catRequests.phpScroll to the bottom of the page and you'll see the image of the vapor system. Good Luck.Yes, but it looks like the hoses through Banzai are more expensive. Banzai charges $120 for the long gas tank hose (GF-23), but you can get Nissan part #17236-E4601 from Nissanpartsnow.com for $84.05.-Mike Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289856 Share on other sites More sharing options...
July 18, 200916 yr Author comment_289900 Thank you, for your help I found 5/8" and 3/4" fuel hose at McMasterCarr. So I'm going to order it from them. I looked up Arne's research and I have a schematic in Wick Humble's book. Darrell 240Z Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289900 Share on other sites More sharing options...
July 19, 200916 yr comment_289911 Thanks for the tip on Nissanpartsnow.com, I wasn't aware of that site. Do you know if these parts are the braided style or just standard fuel hose with the correct bends? Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289911 Share on other sites More sharing options...
July 19, 200916 yr comment_289912 The ones I got from Nissan in '07 were cloth braid-covered, all four of them. Don't know if the current hoses are still covered. Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289912 Share on other sites More sharing options...
July 19, 200916 yr comment_289914 The ones I got from Nissan in '07 were cloth braid-covered, all four of them. Don't know if the current hoses are still covered.I got some a couple of months ago and they were still the braided ones.-Mike Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289914 Share on other sites More sharing options...
July 19, 200916 yr comment_289924 Yep, NOS braided on those that were available. Link to comment https://www.classiczcars.com/forums/topic/32565-help-with-these-fuel-vapor-lines/#findComment-289924 Share on other sites More sharing options...
