Posted
I have been researching OEM shock inserts and have identified the following part numbers:
56105 E4125 normal resistance shock front
56105 E4185 firm resistance shock front
56205 E4125 normal resistance shock rear
56205 E4185 firm resistance shock rear
Does anyone know what causes the shock to be either "normal" or "firm"? Is it the viscosity of the oil in the shock? Is the the internal valving of the shock?
Also, which shock was installed during original manufacture of the 1970 model year?
Thanks,
Keith
https://www.classiczcars.com/forums/topic/32091-240z-oem-shock-inserts/
Probably the valving. But hard to say for certain at this point.
Neither. The inserts were for replacement only, not used in original production. The original struts were assembled inside the tube, not self-contained inserts.
I can answer your second question because I have a parts catalog handy, but will leave the first question to someone more knowledgable.
These are the shock absorbers used up to 07/73.
Front
56110-E4125 - US & CAN
56110-E4126 - HS30 2 seater
Rear
56210-E4125 - US & CAN
56210-E4126 - HS30 2 seater
