Hi all, looking forward to checking out the site. I have a 73 (owned it since 79). It was on the side of my property for about 12 years. Has some cancer on the passenger inner fender well. Looks like I will need to cut it out and rebuild the side and shore up the battery stand. Tried to fire it up today, but no spark. So testing begins tomorrow.
https://www.classiczcars.com/forums/topic/30540-new-guy-in-washington-state/
Wow, after viewing some of the hidden damage on some these posts. I have a feeling it will be way too much work. I really don't plan on a full restoral, I want it to be a weekend driver.
Edited by Heydewd
I hope you changed the oil and filter and shot some oil in the cylinders before you tried to turn the engine over with a wrench. Don't use the starter. When these engines are not running there are two cylinders exposed to the outside air. Plus valve stems are where they are inside the manifolds. Pour oil over the cam and rockers . Then you can turn over the engine if it is not locked up. If you spin the engine with out doing this you can damage things like the cam, rockers, rings that could be rusted to the cylinders walls. If the valve stems are rusty, and the valve sticks down the piston will hit it when it comes up and can bend the valve and or punch a whole in a piston. Also don't flush old gas into the carbs and fuel sysitm it will cause you a lot of extra work. Especially on a car that has been idle outside for this long. with a scoket you can turn the engine over with the nut on the crank shaft in front of the engine. This is preferred because you can feel what is happening and watch the rocker and valves to see that they are moving properly and not sticking. ATF in the cylinders , about a teaspoon full in each, works great to free things up . Put it in and let it soak at least overnight. Good look with this. Gary, I live just outside of Portland.
I followed the instructions as Gary wrote above two years ago and save the engine in mine. Like Gary said make sure everything in moving and clears prior to using the starter to turn it over.
By the way welcome from Tacoma.
Appreciate the tips. Already took care of that prior to cranking it over (I let it sit for another 3 days prior to wrenching on the crank). My major concern is the rust below the battery tray. It has a 3 inch hole. So next week it goes on jack stands and door panels come off to check out how bad things are. I have a feeling in my gut that I will be a seller on Ebay this spring.
Edited by Heydewd
I do have a question. The box rail below, that the fuel lines run on. Is that a structural component? It is rusted pretty bad, but doesn't look to be a strong box to begin with. If it is, I will just part it out.
This is the rail I was speaking of. I borrowed a photo from one of your posts. Mine is rusted bad on the top. I was able to punch holes in it with a screwdriver.
Edited by Heydewd
That's your frame rail, that EVERYTHING sits on... MOTOR and Suspension for example.
Ya, it's very importamt to have a stout frame rail on both sides.
Dave,
Marysville, WA. 20 miles north
