Skip to content
Picture of ITG
When I was searching for pics of installed ITG's, I had a hard time finding them, so not that mine are in, I wanted to post some pictures.
I am still working on the carb bowl vents locations. I am not happy with them as is, but it will work tolerably for now.
Hot Dawg! You've sure done a lot since I last saw you. Looks VERY good, too.
Frank
Hey Frank, you dont know the half of it. I am planning on making the Z Christmas party, its in my neck of the woods. So I can get the wife and baby to show up as well.
How have you been?
Been good! :bandit:
A party scheduling conflict will prevent me from attending this year's party. Maybe I'll see you at AutoRama if you get a chance to stop in....
Frank
Tell me more about the ITG Air Filters..... Did you need to modify the backing plate
to deal with the SU's ? Did you custom order via size measurements ?
http://www.eurosportacc.com/itg_performance_foam_air_filters.htm
Thanks,
Not just a Z - zdisease
When you order the ITG's from MSA they come with the holes needed to mount to the SU's. And thats it. THe orange air box on your stock 240Z has ports for your carb vents, your valve cover, and your tank vent. I had to find ways to run those lines. You can see my initial attempt at connecting the carb vent holes with a single piece of tubing with a vented connector in it. I am not happy with this setup, but mechanically its functional and will not hurt anything.
