Posted July 6, 200817 yr comment_252836 when im hauling arse sometimes the revs will go down to 2k and i cant bring them back up until i kill the motor and let it sit for a while. does anyone know what is going on? Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/ Share on other sites More sharing options...
July 6, 200817 yr comment_252837 Sounds like you're not getting enough fuel. Check your fuel filter for blockage, then check fuel pressure and flow (fuel pump performance). Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252837 Share on other sites More sharing options...
July 7, 200817 yr comment_252866 Snoop, what year is your Zed? Electrical pump plus mechanical or just one or the other. If you have a electrical pump then there is a filter before the pump . Change that one first there is another filter in the engine bay and screens at the ''banjo'' fittings on the SUs . If injected this is a different story. Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252866 Share on other sites More sharing options...
July 7, 200817 yr comment_252869 This is the kid that's 'starting his racing career'. I think he owns a 260Z but that's about all the info he's given here so far other than wanting to buy stuff to make it go fast. It's kind of tough to do anything but guess with that post being all we've got to go on. Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252869 Share on other sites More sharing options...
July 7, 200817 yr comment_252878 i'd trry bypassing the fuel filter to see if u can get more gas Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252878 Share on other sites More sharing options...
July 7, 200817 yr comment_252881 I would drive it off a cliff..... Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252881 Share on other sites More sharing options...
July 7, 200817 yr comment_252883 i'd trry bypassing the fuel filter to see if u can get more gasYou're joking, right? Or should he weld on a hitch as well?A new fuel filter is only a few bucks @ NAPA. I just replaced mine. Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252883 Share on other sites More sharing options...
July 7, 200817 yr comment_252888 without more info... Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252888 Share on other sites More sharing options...
July 7, 200817 yr comment_252890 whell i figured the fillter was clawged up wit rust from the gas tank so it wasnt getting fuel Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252890 Share on other sites More sharing options...
July 7, 200817 yr Author comment_252905 This is the kid that's 'starting his racing career'. I think he owns a 260Z but that's about all the info he's given here so far other than wanting to buy stuff to make it go fast. It's kind of tough to do anything but guess with that post being all we've got to go on.i know i know... i thought building a racecar would be a lot less expensive than it actually is.. so i decided to take my car and build it into something i could escape from a bank robbery in. Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252905 Share on other sites More sharing options...
July 7, 200817 yr Author comment_252906 Snoop, what year is your Zed? Electrical pump plus mechanical or just one or the other. If you have a electrical pump then there is a filter before the pump . Change that one first there is another filter in the engine bay and screens at the ''banjo'' fittings on the SUs . If injected this is a different story.its a 73 and it has an electric fuel pump Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252906 Share on other sites More sharing options...
July 7, 200817 yr comment_252910 Solution: Quit haulin' arse.....Seriously, a lttle more info.What carbs? Flat top or round top? How much fuel pressure are you running? Are your float levels correct? Even though the carbureted Z is simplicity personified, relatively speaking, there is more to it than just putting your boot in it..... Link to comment https://www.classiczcars.com/forums/topic/28653-this-is-beyond-me/#findComment-252910 Share on other sites More sharing options...
