Hey all, I'm looking for 16 lug nuts that will fit the '82-'83 280ZX Swastika wheels so I can put them on my 240Z. All the ones I find locally either have a shaft that is too long, or too big around, and will not fit correctly. If anyone has anything they will sell cheap, then please PM me. I'll need to see pictures to make sure they will work. Thanks!
Greg
https://www.classiczcars.com/forums/topic/27558-wtb-lug-nuts/
Do you have a junkyard near you? That would be your best bet. I have plenty of those lug nuts but the shipping would probably be more than I'd charge for the lug nuts themselves. They're a Nissan only item. Same lug nut was used on the Swatika, the Iron Cross, the Snowflake, the 810 factory alloy, the so called 'Black Pearl' wheel, and I'm sure many others. 40224-R4670 is the present Nissan part number, and they still have them, but you really wouldn't want to buy them new since they're about 7 bucks apiece.
Thank you guys. I did check with John at the swap meet and he didn't have anything. I'm going to join the official local club and then I can get a discount at the dealer. I've checked all over otherwise and no one has any. sblake, if I have any trouble getting them from the dealer for some reason, then I may want to get them from you anyway. If so, I'll PM you. Thanks!
Greg
For the lug nut in question, unless you know the exact measurements, a specialty shop won't do you any good and maybe not even then. Like I said, it's a proprietary Nissan lug nut. If you have a local junkyard, that's your best bet. If you go to a dealer, or shop like Stockton wheel, you're just spending extra money unnecessarily.
<html>
<head>
</head>
<body style="visibility: visible;">
They're a Nissan only item. Same lug nut was used on the Swatika, the Iron Cross, the Snowflake, the 810 factory alloy, the so called 'Black Pearl' wheel, and I'm sure many others. 40224-R4670 is the present Nissan part number, and they still have them21m51fo.jpg
Hey guys, Is this the right lug nut. Right now priced very reasonably on eBay: <a title="Click Here" target="_blank" href="http://cgi.ebay.com/ebaymotors/Datsun-280zx-6-spoke-wheels-rims-lug-nuts-240z-280z-S30_W0QQcmdZViewItemQQcategoryZ42609QQihZ015QQitemZ250231604446QQrdZ1QQsspagenameZWDVW">Auction Item</a>
<br />
</body>
</html>
If you can do better than I'll just go through you....except I've got the high bid right now.....I guess if I don't win then I'll give you a shout. I need something that will work....
Greg
