For our American freinds who think Quantas is the safest airline in the world.
P: stands for the problem the pilots entered in the log
S: stands for the corrective action taken by the mechanics.
P: left inside main tire almost needs replacement
S: almost replaced left inside main tire.
P:test flight OK' except auto land very rough.
S:Auto land not installed on this aircraft.
P: something loose in cockpit.
S: something tightened in cockpit.
P:Dead bugs on windshield.
S:Live bugs on backorder.
P:Auto pilot in altitude-hold mode produces a 200-fpm descent.
S:cannot reproduce problem on ground.
P:Evidence of leak on right main landing gear.
S:evidence removed.
P:DME volume unbelievably loud.
S:DME volume set to more believable level.
P:Friction locks cause throttle levers to stick.
S:That's what they're there for.
P:IFF inoperative.
S:IFF always inoperative in OFF mode.
P:Suspected crack in windscreen.
S:Suspect you're right.
P:Number three engine missing. ( note: this was for a piston engined airplane;the pilot meant the engine was not running smoothly)
S:Engine found on right wing after brief search.
P:Aircraft handles funny.
S:Aircraft warned to straighten up, fly right, and be serious.
P:Radar hums.
S:Reprogramed radar with words.
P:Mouse in cockpit.
S:Cat installed.
https://www.classiczcars.com/forums/topic/2736-quantas-maintenance-log/
  • 1 month later...
That should be spelt QANTAS - its and Australian domestic/international airline. And no, there should not be a 'U' after the Q because the name is an abbreviation of "Queensland And Northern Territory Air Service".
You're RIGHT! there is no 'U'! I have a vintage Australian travel poster hanging over the toilet in my bathroom and I have stood there...well...quite often....and read that a million times and never realized there was no 'U'. Interesting. Great trivia question.
So what does BOAC stand for?
steve77
