Posted January 24, 200817 yr comment_235232 Hi,I'm wondering if those people out there with a 260 or 280 2+2 might be able to tell me what the front track (in mm) is on their car from the face of the brake rotor that the wheels bolt to.Also the distance between the bolts that hold the front crossmember to the rails.I understand the 2+2 bodys are wider but I'd like to know if a 2+2 front end would go into a 240z to increase the track without having to run 9inch & offset wheels to fill out bolt-on gaurd flares.I think setting the wheels that far out from where the suspension was designed to have them would throw off it's geometry and create excessively heavy steering and am looking for other options.If the track and crossmember were close I'd have to look at the strut tops, caster bars but they would probably be fairly straight forward to "make fit".I'd appreciate any help/advice or comments. Link to comment https://www.classiczcars.com/forums/topic/26871-help-wanted-2-seater-vs-22-front-track/ Share on other sites More sharing options...
January 24, 200817 yr comment_235242 2+2 bodies aren't wider. the track is the same at the front (and at the rear too I believe). The 2+2 doesn't taper as much in the rear to accommodate the rear seat, so the rear tail light panel is wider than the 2 seater, but overall they are the same width. Link to comment https://www.classiczcars.com/forums/topic/26871-help-wanted-2-seater-vs-22-front-track/#findComment-235242 Share on other sites More sharing options...
January 26, 200817 yr Author comment_235478 Ah, that makes sense. I accidently bought a 2+2 bootlid spoiler a while back and it was too wide, I'd also read in a gregory's (I think) manual that the 2+2's are wider but they probably only meant at the rear without saying it. Link to comment https://www.classiczcars.com/forums/topic/26871-help-wanted-2-seater-vs-22-front-track/#findComment-235478 Share on other sites More sharing options...
February 28, 200817 yr comment_238897 Front crossmembers are the same on both cars, the only major difference is in the rear suspension A-arms on the 2+2. Rear track is wider to accomodate the rear seats. If you put in adjustable lower arms on the front you could increase track slightly.... Link to comment https://www.classiczcars.com/forums/topic/26871-help-wanted-2-seater-vs-22-front-track/#findComment-238897 Share on other sites More sharing options...
February 28, 200817 yr comment_238899 I have a 77 2+2 awaiting disassembly (winter snows) and i will be interested in comparing the coupe vs 2+2 rear arms. Link to comment https://www.classiczcars.com/forums/topic/26871-help-wanted-2-seater-vs-22-front-track/#findComment-238899 Share on other sites More sharing options...
July 8, 200817 yr comment_253015 Hello, I have a 2+2 and have been looking for a spoiler. Where did you get yours at? Link to comment https://www.classiczcars.com/forums/topic/26871-help-wanted-2-seater-vs-22-front-track/#findComment-253015 Share on other sites More sharing options...
