In addition to the bolts in the front, there are bolts on either side near the ends. Finding them can be tough if there is a lot of built up dirt and debris built up over the years. They are below the marker light, close to the seam where the headlight bucket attaches to the fender.
If you have a 240, you can unbolt the bumper mount itself from the inner body under the hood hinges, or you can unbolt the mount from the bumper itself. It's a bit easier to take the bolts from the mounting bracket on the frame, the ones behind the bumper can be a pain if they are rusted badly.
