March 30, 200619 yr comment_161739 Hi dadz:I'm glad I qualified by earlier statement with "as I recall".I've been doing some farther research.. trying to pin down the various dates at which the Tire Safety Standards related to displaying the production dates changed.. and they seem to have changed quite often over the past 40 years. Sorry to say that the Federal Register is very hard to follow between "proposed changes" and "actual changes implemented".I know "think".. that the "K7" is the Plant Code that indicates what production plant the tires were produced at. I've written some contacts at Bridgestone to see if they can dig up some history for us.Does your tire say K7002 or K7000 or K7009? I can't quite be sure from the picture.There should be another set of characters molded into the sidewall - what do they say?I think we need to gather a few more samples... regards,Carl Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-161739 Share on other sites More sharing options...
March 31, 200619 yr comment_161773 I am willing to part with the spare but won't be able to confirm anything until I get back to the car around the end of April if everything goes as planned. I am in the Crystal River area of FL and do get down to Sarasota/Bradenton fairly often to go sailing. Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-161773 Share on other sites More sharing options...
March 31, 200619 yr comment_161845 Jrome,I am patience, thanks for the update.Regards,Keith Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-161845 Share on other sites More sharing options...
April 5, 200619 yr comment_162332 Hi dadz:I'm glad I qualified by earlier statement with "as I recall". I've been doing some farther research.. trying to pin down the various dates at which the Tire Safety Standards related to displaying the production dates changed.. and they seem to have changed quite often over the past 40 years. Sorry to say that the Federal Register is very hard to follow between "proposed changes" and "actual changes implemented". I know "think".. that the "K7" is the Plant Code that indicates what production plant the tires were produced at. I've written some contacts at Bridgestone to see if they can dig up some history for us. Does your tire say K7002 or K7000 or K7009? I can't quite be sure from the picture. There should be another set of characters molded into the sidewall - what do they say? I think we need to gather a few more samples... regards, Carl Carl, I checked today the characters stamped into the sidewall and they read as follows: K7002 V-I DOT R20N I hope that this helps? Also kats was able to decode another Showa date found on the itemized list in the toolkit which reads: 45.8.15 which is decoded as August 15, 1970. This date coincides with the doorjamb tag of 08/70. Now if we could decode that sidewall we would be getting somehwere. As a sidebar 'kats' was also kind enough to let me know the historical significance of this day in history. It is the day that Emperor Hirohito is broadcast to the people of Japan ending World War II. Image of toolkit list: Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-162332 Share on other sites More sharing options...
March 17, 200817 yr comment_240897 Possibly an unused spare wheel and tyre from a 240Z click here Hope it helps someone! Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-240897 Share on other sites More sharing options...
July 12, 200817 yr comment_253431 Hi guys. Only 23 hours to go!! Ebay Australia.Item number: 220253086892 http://cgi.ebay.com.au/eBayISAPI.dll?ViewItem&item=220253086892#ebayphotohosting Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-253431 Share on other sites More sharing options...
February 23, 201114 yr comment_347056 My latest acquisition:http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290537581144&viewitem=&sspagename=STRK%3AMEWNX%3AITMy wife thinks I am planning to open a tire store!Keith Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-347056 Share on other sites More sharing options...
February 25, 201114 yr comment_347231 I have a Toyo that I took off the spare rim. Link to comment https://www.classiczcars.com/forums/topic/18989-1971-240z-oem-bridgestone-17514-value/?&page=3#findComment-347231 Share on other sites More sharing options...
