nice i got the same one. Those Flairs look perfect with that airdam. Im forsure gona do that. ur car is gourgous!!!!!!!
thanks. You have to trim about 3 inches of the front of the flares to make them work with the airdam. Also, a lot of people use VW welting between the flare and the fender. I used 3m trim adhesive tape from pepboys instead, which also held the flares attached while I drilled the mounting holes.
Oven is for powdercoating, the fridge is for essential hydration! You can see the Z31 brake that I powdercoated 350Z daytona blue for someone today hanging in the first pic here
Prox, yes, they are 15" rewinds, from the NASA deal. $275, delivered!
Got a link to where this deal was at? =D
http://forums.hybridz.org/showthread.php?t=101740&highlight=nasa+konig
bubble, its not over the car, but a couple feet from it.
