Posted May 16, 200520 yr comment_124008 Hey guys finally I had a feiw days off to work on the car. I bought new rear cylinders and pads nd front callipers and shoes.I had the drums and the rotors turned and im replacing the flex lines asap.Went and tested it and it actualy worked! All 4 wheels locked up and she slid to a stop!Finally. Now i get to do stearring (sp) and suspension.Shoes, pads, calipers and cylenders = $270.00The thought that i actually acomplished something, Priceliss. :classic: Link to comment https://www.classiczcars.com/forums/topic/15926-update/ Share on other sites More sharing options...
May 16, 200520 yr comment_124010 Good news Bill. So now you have a $270 Z car. Chris Link to comment https://www.classiczcars.com/forums/topic/15926-update/#findComment-124010 Share on other sites More sharing options...
May 16, 200520 yr Author comment_124011 . yup going to branson Mo next weekend to Z fest. Then ill do something else with it! Link to comment https://www.classiczcars.com/forums/topic/15926-update/#findComment-124011 Share on other sites More sharing options...
May 16, 200520 yr comment_124067 Hey Bill, are you keeping a record of all the costs you incur with the project? Link to comment https://www.classiczcars.com/forums/topic/15926-update/#findComment-124067 Share on other sites More sharing options...
May 16, 200520 yr Author comment_124068 yup. Valve cover gasket 35.00Master cylinder. 45.00shoes 15.00pads 10.00rear cylenders 65.00 eachcalipers 60.00 eachRotors turned 7.00 each drums turned. 7.00 each Link to comment https://www.classiczcars.com/forums/topic/15926-update/#findComment-124068 Share on other sites More sharing options...
