You know that feeling you get when you listen to Queen playing We Will Rock You? Well, you will have that kick arse feeling all day when you own this part!
Everyone one on ebay is a sales person.
If you had been heated up red hot then you would probably be burnt as well! ROFL
Unless it's ceramic coated [or otherwise protected] then any metal oxides after exposure to high temperature.
Personally, this is one item I wouldn't buy by auction as you still need the other bit's to finish off the project! [not to mention the if it still works factor].
Yeah you will get that kickass feeling, when you realise you have been ripped off, you'll want to kick the sellers arse.
Anybody else notice that theres a turbo, and an exhaust manifold, and a couple of other bits of junk one looks like a external wast gate, but no intake, plenum chamber or any kind of fuel delivery system. No dump pipe either.
Also the way the turbo looks like it mounts on the exhaust manifold, looks like it wont fit in the engine bay.
Stick with the factory parts.
