Junk Yard Z - Open Discussions - Classic Z Car Club Skip to content
Junk Yard Z
Just wanted to post some pictures of a 240Z in a junk yard thats one of the last old school yards around me in PA. Its quite picked over and is literally dis-integrating. I am in the process of extracting the strut housing from it to modify them to accept coil overs so that I can keep my originals. So far Ive managed to get just the LF. I also found a penny in the car dated 1982 so I assume thats around when the car was sent to the yard. It appears to be what I believe an early 71 car as it has the 7 in brake booster, and the vertical defroster grid on the glass, and the jack and tool stowage up over the luggage riser under the hinged lids. Both data plates are missing and the area on the firewall where the VIN is stamped is heavily rusted and pitted so I cant make out a VIN number. I'll likeley be snagging the glass and what ever else i can off of it. The rear diff and axles are still there too.20260326_145759.jpg
A 620 pick up parked right beside. This yard has a few dis-integrating Datsuns. Even an F10!! Sad sight to see honestly.
Not a Datsun but still a grail of a find Mazda REPU!!! Im not sure if its an actual REPU or the I4 powerd truck but one of the best looking small Japanese trucks IMO. Again, rusted into oblivion.20260326_121952.jpg
810 wagon. And before you ask, no its not a diesel I already checked ☹️IMG_20210515_140057.jpg IMG_20210515_140111.jpg
It's probably a latter 71. The body vents are in the pillar and not below the rear glass in the hatch. The VIN is probably higher than HLS30-21000. I guess Datsun hadn't run out of vertical defroster glass yet when the car was built. You might want to retrieve the rear hatch glass.
