Retrosound Radio - Shop Talk - Classic Z Car Club Skip to content
Retrosound Radio
I bought a retrosound radio to replace an older tape deck. The previous owner had shredded the old harness but I mostly got it back to stock. Hooked up the blue 12v constant, ground, and speakers for both sides.
It requires an additional power for illumination. I can’t seem to figure out ignition switched 12v, so the radio doesn’t turn on. I have a Red-blue, and a green-white left. Checked fuses and still not getting anything on the voltmeter when ignition is on for either wire.
Wouldn’t be surprised if it’s a me problem, but the frustration is rising. Thank you!
Green/White = Positive for gauge lights
Red/Blue = Returns gauge lights to the rheostat (gauge light dimmer)
Blue = Accessory (Key Switched)
Constant power would be come from the cigarette lighter (Blue/White)
Steve, though I’m sure you’re not surprised, it worked! Thank you!
Absolutely! Will take me a little while, but the quality and sound were great on the test run!
