Skip to content
Screws for the instrument console finisher (ICF)
  • 1 month later...
On 9/28/2025 at 1:13 PM, zKars said:
They are black M4 x.7 yes. Oval head is what I believe they are called, not flat, slightly curved face. Phillips or JIS equivalent driver. Fairly long, like 25mm?
WHat about the 3-5 screws on the center console? I lost the original screws. anyone?
I used 5/8"-long pan head Phillips sheet metal screws on the sides up front. I don't know how to specifically describe sheet metal screws. For the three screws in the "glove bin" I used M5-0.8x12 countersunk Phillips screws. All the screw heads were spray painted flat black. The heads of the M5 screws I used are a smaller maximum diameter than are the countersink holes in the bin so perhaps the OEM screws have a special head to make them flush with the bin floor.
My 1972 FSM (Section 123) shows holes for the front screws (for "floor finishers" from Aug '71 it says) but no screws are shown in the drawing. The rear three screws are likewise nowhere to be seen.
Edited by Seppi72
clarified FSM section
