19 hours ago, Mitchel0407 said:
That’s an awesome piece of kit! Once the car has been repair and on the road again I’ll come visit to test it out!
That would be nice, only give me a heads up, the meter uses one big 1,5V battery and the new one that came in the case with it was a bit...empty! Luckely it wasn't IN the battery compartment as it was well rusted haha! The battery contacts have never seen a battery i think as they are flawless!
Dit keer lag het wél aan de VARTA! ;-)
Translated : This time it WAS the battery from VARTA that was dead! Once there was a commercial in the Netherlands of Varta that said: it can't be the battery because that's a VARTA! ;-) but they don't hold for 40+ years!
  • 3 weeks later...
On 10/3/2025 at 11:26 AM, Zed Head said:
The car has independent rear suspension. There are two drive shafts in the back and no single axle. The inspection probably identified a misaligned wheel. That could simply be worn control arm (transverse link) bushings. Or even spindle pin bushings. Also readily available.
