Posted Friday at 07:44 PM4 days comment_677185 1978 Z. Started the car, all of a sudden my left blinker went on. Couldn't control it from the stalk. Staid on when the car is shut off. Disconnected the stalk from the wiring harness. The blinker stayed on. I finally stopped it by pulling the blinker relay. Thoughts? My first thought is to replace the relay.Thanks Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/ Share on other sites More sharing options...
Friday at 08:07 PM4 days comment_677186 It's probably the mechanism in the combination switch.Not likely to be the flasher. There is no separate turn signal relay. Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677186 Share on other sites More sharing options...
Friday at 08:10 PM4 days comment_677187 Pretty easy to remove. Something I learned - the ring around the ignition switch will pop out about 1/8" to allow you to remove the plastic shield around the column without breaking the corners off. Appears to be designed for that purpose. Edited Friday at 08:13 PM4 days by Zed Head Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677187 Share on other sites More sharing options...
Friday at 08:32 PM4 days comment_677188 On second thought it might be the Hazard switch. Lots of mysteriousness in there. It has power when the key is off.@SteveJ seems to feel comfortable with it."even when car is off" Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677188 Share on other sites More sharing options...
Friday at 11:06 PM4 days comment_677190 Has anybody worked on the wiring to "fix" a problem? Those "fixes" frequently involve finding some wire with voltage and tapping into that.The turn signals are powered through the ignition relay. If the key is not in ON, the ignition relay won't complete the circuit for the turn signals,As @Zed Head suggested, the next thing to look at would be the hazard lights. Normally if you pull the hazard switch that would kill the power to the turn signals. If the blinker is still going with the hazard switch disconnected, that would indicate some creative wiring has been done to the car.You can also pull the turn signal fuse to see if that kills the problem. If not, pull the hazard light fuse. The turn signal fuse is in blue, and the hazard light fuse is in red below.If neither fuse fixes the problem, that still points to creative wiring.More questions:How long have you owned the car?Have you experienced any other electrical glitches?Look under the dash on both sides and around the kick panels. Do any wires look like they have been spliced, cut, or otherwise altered? If so, look for wire colors (with stripes).Do you see any electrical tape that looks newer than the wiring harness? Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677190 Share on other sites More sharing options...
Saturday at 02:10 AM4 days Author comment_677192 This is all great stuff. Thanks. I'll dig into it this weekend. The Hazard light circuit is a high contender since it is the only one to bypass the ignition power circuit. The second thing that points to this is that I took the turn/combination switch/stalk out, unplugged it, and it was still going. Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677192 Share on other sites More sharing options...
Saturday at 11:05 AM3 days comment_677200 If only the left side is blinking with the hazard switch, that means you have another problem as both sides should be blinking with that switch. Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677200 Share on other sites More sharing options...
Saturday at 09:32 PM3 days comment_677214 Are you sure? The diagram shows a left side and a right side, from the Hazard switch. It's a 78, I didn't look at any other diagrams.The Hazard switch is basically a gate between power and the flasher, and the lights. Since the flasher comes in to play the short to power has to include the flasher circuit. Basically it's just completing the circuit, like a short across contacts inside the switch. Interesting problem.For what it's worth, I erased about three different paragraphs about this problem. Writing about it does help the brain work... Link to comment https://www.classiczcars.com/forums/topic/69451-blinker-wont-stop-even-when-car-is-off/#findComment-677214 Share on other sites More sharing options...
