Hello all,
I recently over cranked my window and heard a loud POP and stripped out the window regulator in my driver door. I'm wondering if anyone happens to have a spare for a 70-73 that I can buy. I haven't had any luck sourcing one.
Edited by iDrift
  • iDrift changed the title to 240z LH Window Regulator for Driver Door
Yep, I took it out and inspected it. The rollers were all still intact and in their guides. The popping sound is made whenever you roll the regulator all the way up to where the glass should be fully seated. When the gear on the back of the regulator makes it to the end of its travel, instead of stopping it slips off the track and the pop noise is the spring forcing it back down. I'm thinking there used to be a stop on the track but the initial loud pop I heard was perhaps the last tooth on the track snapping off.
It sticks in my mind that I read a write-up of how to repair the window regulators some time ago.  It may be worth searching for ways to repair what you have if you have not already done so.
