May 21, 200322 yr comment_38206 I'd check the plugs for soot (as above) to find out which cylinders are running rich. Have you refilled the car lately? Sometimes dodgy fuel will do exactly what you describe.. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38206 Share on other sites More sharing options...
May 21, 200322 yr comment_38238 Alpha I think the problem you mention is something similar to what I had. First do you have an electronic dizzy?If not replace the condenser & points in the old mechanical distributor.There both very cheap. Have you changed your coil? The coils are known to pay up after the car has warmed up. Just a thought. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38238 Share on other sites More sharing options...
May 21, 200322 yr Author comment_38239 Alright Gav, I'll check that too tomorrow...Mmmm... now I need to find out all about Dizzies!I take it I can buy new parts (coil, condensor, points) at a regular auto shop? Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38239 Share on other sites More sharing options...
May 21, 200322 yr comment_38240 If everything else mentioned is o.k. check your float level. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38240 Share on other sites More sharing options...
May 21, 200322 yr comment_38241 Its not a problem to buy them at your local autor parts shop, and installing them is pretty damn easy, however, there are usually lots of little plastic spacers/washers, if you don't get them in the right place, and they earth, your car will never start. Just take it easy and pay attention to what goes where, the condenser is also a possibility, when they heat up, they tend to not work well absorbing the extra spark and your car farts and pops when you rev it. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38241 Share on other sites More sharing options...
May 23, 200322 yr Author comment_38603 Wasn't the points or the condenser... I'm thinking float level! Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38603 Share on other sites More sharing options...
May 23, 200322 yr comment_38610 Hold on, you haven't pulled the plugs yet!!!!! Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38610 Share on other sites More sharing options...
May 24, 200322 yr Author comment_38624 plugs are black and sooty, yea, running rich alright. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38624 Share on other sites More sharing options...
May 24, 200322 yr comment_38625 Good, Now I can sleep tonight. Link to comment https://www.classiczcars.com/forums/topic/6244-idling-makes-him-sick/?&page=2#findComment-38625 Share on other sites More sharing options...
